跳转到主内容
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
Guide for replacing lightning port
Hi, I see you sell the part for replacing the lightning port on a 12 pro max, but I can’t find and ifixit guide on the subject, is one available?
I’ve had the phone since launch, it’s now stopped charging unless placed in a specific position, I’ve cleaned the port, tried multiple cables and chargers with no luck, I’ve only ever used MFI certified anker or apple cables. Is there anything else I can try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Other than replacing the iPhone 12 Pro Max Lightning Connector Assembly I can't see any other answer.
完成的
添加一条评论
4个答案
最有帮助的答案
Hi
As @danj had said ,it’s probably time for a new lightning port
However
When you cleaned it did you clean it properly,I suggest you look at it again and use a pair of fine tipped tweezers or a seeing needle to clean it and finish it off with some isopropyl alcohol
Iv seen many lightning ports that claim to have been cleaned but they aren’t cleaned properly
If that doesn’t work it’s time for a new port
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 2
6条评论:
Thank you for your advice!
I did use a pair of fine tipped tweezers but will try some alcohol.
How do I request a guide on how to do this from ifixit? It makes no sense to me that they sell the part but have no guide
完成的
@telstar17
Unfortunately I think all you can do is request they make one over on ifixit meta(linked below)
https://meta.ifixit.com/
If it comes to replacing the port I can get you one if you would like but it won’t be from ifixit:-)
完成的
I will do that!
I just tried the isopropyl alcohol and fine tipped tweezers and was shocked how much rubbish came out, I’ve never had so much in there before and have always managed to clean it with just tweezers. It seems to be charging much better! Thank you so much for your help!
完成的
@telstar17
Your most welcome!
Please let me know if there’s anything else I can help with:-)
完成的
Hi, im also facing the issue. Is there any way I can get a charging port fairly cheap?
完成的
显示更多的1条评论
添加一条评论
As Said By Dan, I don't think any other option exist better try replacing the post before it transcending
这个答案有帮助吗?
得分 1
添加一条评论
Hi John,
Glad to hear you got your phone working again without having to replace the charging port!
Just for future reference for you or anyone else looking for a guide, although there isn't one here in iFixit yet, there is a French site called SOSav that does have a very usable guide for replacing the iPhone 12 Pro Max charging port. There are some idiosyncrasies in the translation such as calling flex cables 'tablecloths' and Phillips screws 'cruciform', but outside of those it's very usable.
Charging connector iPhone 12 Pro Max repair - Free guide - SOSav
这个答案有帮助吗?
得分 1
添加一条评论
i found a youtube video on how to do it hope this helps
https://www.youtube.com/watch?v=dSy_kjkR...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 14
过去 7 天: 48
过去 30 天: 222
总计 7,552
