跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Why does my motherboard speaker do no beeps?
Ryzen 3 3100
Rx 580 8 gb
16 gb ram
Msi a320m a pro max
Evga 600w
All my fans spin
Recently my old graphics card had been losing signal after a couple of minute, so I bought a new one and now the motherboard won’t beep and won’t give signal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Do you get beeps if you remove the GPU card and then try starting the PC?
It should give a beep error code because there are no graphics adapters detected. (Award BIOS 1 long, 2 short, AMI BIOS 8 beeps, Phoenix BIOS 3-3-4 or 3-4-1)
Do you get 1 beep if you start the PC but still get no video signal?
If so this means that it has passed POST and should be booting into Windows. (Unless you have Phoenix BIOS and then there is no beep for a successful POST - Award BIOS and AMI BIOS give a single beep for a successful POST)
If you determine that it is booting into Windows without a display, can you get into BIOS with a display?
这个答案有帮助吗?
得分 1
4条评论:
I get no beep even if I remove all ram and my gpu
完成的
@Anonymous
Check that there is a speaker connected across JFP2 as shown in the user manual on p.11.
If there is make sure it works. Remove it and test with an Ohmmeter for continuity through the speaker or try another speaker.
完成的
I don’t have an ohmmeter and it is plugged in jfp2
完成的
@Anonymous
Either the speaker is faulty or the PC is not even starting to POST even though the fans are working.
What lights are on if any - keyboard, PC case, motherboard etc?
完成的
添加一条评论
添加你的答案
Anonymous 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 559
