跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A22 5G 是一款由三星电子研发和制造的中端 Android 智能手机,属于 Galaxy A 系列。该手机于 2021 年 6 月 24 日首次发布。手机配备了后置三摄像头系统和 90 Hz 电子显示屏。其电池容量为 5000 mAh,比 iPhone 13 Pro 的电池大了 62%。
Fingerprint scanner not working
The button is working properly but the sensor is not working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
It's f42 5g but it's not working but after restarting it's starts working for few minutes only.
由完成的
Sensor not work button is ok
由完成的
Fingerprint not working sencer
由完成的
Please working my fingerprint option Please 🙏 😢 Please
由完成的
Finger print not working
由完成的
添加一条评论
5个答案
最有帮助的答案
@siddhantsen @gulfamkhan @fathimaraihana the very first thing you want to do, is to tell us what you all have tried to fix this. You have to determine if this is software or hardware related. A couple of common things to do, is to do a soft reset first. Then check for any software updates. Make sure you have the latest software for your phone. So go to your phone's settings menu, then look for the "software update" or "system update" option. If there is an update, download and install it. Next clear the cache and data of the fingerprint scanner app. You should also remove and then add your fingerprints once more. For more of all of this, check Samsung's advice on here
If none of this worked, you should consider replacing the fingerprint scanner. In the case of your phone the fingerprint scanner and the power button are combined. Since there are no guides on iFixit for this (yet) use something like this video to replace it. Remember that you need to purchase a proper replacement for your version of the A22 (SM-A226B, SM-A226B/DS, SM-A226B/DSN) to ensure compatibility. You can purchase those at many places online. Pick a vendor that meets your expectations.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
得分 1
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
添加一条评论
My phone fingerprint not working
这个答案有帮助吗?
得分 0
添加一条评论
Yes is now working as manual
这个答案有帮助吗?
得分 0
添加一条评论
مشلكة لايوجد البصمة a22
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SIDDHANT SEN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 47
总计 3,016
