跳转到主内容
Guides and support for devices that play video from DVDs.
Laser Head Cleaning Method
What is the proper method for manually cleaning the laser head when a cleaning disc cannot do the job? (dvd disc skips)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What about the lens itself; can you use isopropyl alcohol with a cotton applicator?
完成的
添加一条评论
1个答案
已选择的解决方案
Depending on the player I would clean the rails and the screw which moves the head. Use a can of can'ed air to blow the debris out you might find a small soft paint bush is only needed to loosen the junk.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
William Stalzer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
