跳转到主内容
加入维修社区 - 创建账户
nvme ssd i/o
I wanted to know if you have a video or instructions on how to repair the nvme ssd I/O? I lift it one time too hard and it lifted the pins from the board. But I placed some thermal pad on it and it was applying pressure to keep the pins in the board and was working for a while.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ha Nguyen it does not look like there are any instructions for that available. We really would need to see what you have going on there. Going by your description it appears as if you will need to resolder those connections. Applying pressure will fail since the pressure you applied, will become less over time. The proper way would be to solder it. Post some good pictures of the damage etc. with your QUESTION so we can see what you see.
Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ha Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 354
