跳转到主内容
加入维修社区 - 创建账户
HP Notebook 15-ba018ds 是一款配备 Windows 10 操作系统的笔记本电脑,支持触摸屏。合上盖子后尺寸为 16 x 10 x 3 英寸,重 4.83 磅。
Why are these voltage differences?
Hello everyone.
Please, I would like your help in order to help me understand what and why are these small voltage differences on laptop batteries when going for new buy for replacement.
laptop model is:HP Pavilion 15db1027nv
HP original battery is: HT03XL (or REPLACE WITH HP SPARE L11119-855)
On original battery also:
11.55V
41.7Wh
3470mAh
Just exactly like here:
https://www.amazon.com/Compatible-L11421...
But, on many selling sites, the elements (Volts, Wh, mAh) differ a little, just like here:
https://www.aliexpress.com/item/10050041...
Here, Voltage is not 11.55 but 11.40.
a. On replacement, shouldn't voltage be EXACTLY the same? If second battery, with 11.40V is bought and installed, what are the coincidences? Could it cause any damages?
b. What and why batteries are produced even with this small differences?
Thank you for your time!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@johnyb98 shouldn't voltage be EXACTLY the same? No. The voltage listed is the nominal voltage and does not take the typical end-of-discharge and max charge voltage and other variable like ambient temperature etc. into consideration. That is why variations are absolutely normal. You do not know the state of the new battery vs. the old battery. Could it cause any damages? Not it it is within the parameter of your device (don't use a 12V battery on a 5V device;-). remember that even batteries are now smart devices. There are circuits that control over and under voltage (within reason) and the 2% difference in your battery most certainly will not do any harm to your system. Remember, you do not know the charge state of your battery. You are good to use that battery without any sequalae to your computer.
这个答案有帮助吗?
得分 2
1条评论:
Thank you very much for your answer and these precious technical information!! You totally helped and covered on my questions.
由完成的 分享
添加一条评论
添加你的答案
John Eidert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 26
总计 388
