跳转到主内容
加入维修社区 - 创建账户
Galaxy A20s 是一款由三星于 2019 年 9 月发布的 Android 中端智能手机。可以通过型号 SM-A2070、SM-A207F/DS 和 SM-A207M/DS 进行识别。
Network not working. No service problem
Samsung A20s network not 🚫 work. This kind of problem fix by network ic replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 23
13条评论
Network is very slow in my area
完成的
@ankitsharm65627
have you contacted your service provider about the problem?
完成的
No power on ,, problem wifi
完成的
Camera not on and problem wifi
完成的
احمد اليماني did you check the link in my answer? What did you check?
完成的
显示更多的8条评论
添加一条评论
1个答案
最有帮助的答案
Esu Worku yes, it is absolutely possible that the IC is your issue. Of course you do need to check your antennas etc. as well as the components on your circuit boards to ensure that those are ok. You also want to take a look at videos like this that show possible fixes. Don't change IC's just for the sake of changing and hoping it will work.
这个答案有帮助吗?
得分 6
添加一条评论
添加你的答案
Esu Worku 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 3,847
