跳转到主内容
加入维修社区 - 创建账户
Logitech G533 无线游戏耳机的维修与拆解信息。G533 可通过型号 A-00072 进行识别。它于 2017 年 1 月发布。
Why do they not charge
My G533 headset won't charge or turn on no lights come on either I've tried different charging cable and PC and still doesn't work the battery is fine just the charging port I think help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Harvey walker, if you are certain that your cables are good and that the chargers are working, it could most likely be your charging port. Use something like this Logitech G533 耳机如果不插 USB 线就无法工作 to get to teh PCB. Check the charging ports soldering connection and the wiring. If that looks alright you want to use a multimeter and see if you get power etrc. on the broadside of the connector. If not then consider replacing it or resolder. Post some good pictures of your work with your QUESTION so that we can see what you see. BTW tell us how you know that the battery is okay.
这个答案有帮助吗?
得分 1
添加一条评论
Try cleaning the port using some kind of brush! (E.G: Toothbrush)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harvey Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 5,070
