跳转到主内容
加入维修社区 - 创建账户
Samsung 55英寸智能电视(型号为 UA55JS8000 或 UA55JS8000W)的维修信息。
Screen done ppartially dark
I have a Samsung ua75ju6400
Turned it in yesterday and 3/4 of the screen is dark. When I put it against a white background it’s green
I have done a pic test see images
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Screen completely black when TV is on you will hear only sounds no pictures
由完成的
添加一条评论
1个答案
最有帮助的答案
carina.dimaranan at first look it appears as if that this a backlight issue but the green color etc. would be very odd for the backlight. This actually looks more like a panel issue. You could try and take a look at the boards. Remove the back cover from your TV. The main board is the one where all the video inputs connect to. See if you can make out anything that looks odd, like charred or even missing components. Of course, you can also post some good pictures of all of the boards with your QUESTION. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 1
2条评论:
do you know if the panel is replaceable?
When you say panel do you mean the lcd film?
由完成的
@carina.dimaranan those are not readily replaceable. Hard to come by and when you can find them most often they are more expensive than a new TV. It's the LCD assembly so basically your complete screen. Take a look at the boards for now and focus on the main board.
由完成的
添加一条评论
添加你的答案
carina.dimaranan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 760
