跳转到主内容
Released in 2004 and identified by model number J3680. Compatible with Windows 2000 and newer software, and with OSX 10.3.8 and above.
7 个问题 查看全部
How to repair the document feeder
How to repair the document feeder on an HP Officeject J3680 all-in-one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Do you hear the feeder motor turn on to indicate its ready to accept documents? If not, there may be a sensor, motor or software malfunction requiring someone familiar with step by step diagnosis, troubleshooting and repairs if its worth repairing. As a diyer, you might find help on youtube or other forums related to HP Officejet products. HP may have forums too for disseminating info.
完成的
First, let me thank you very much for your reply to my question. Second, I had forgotten that I had asked the question, so I am sincerely grateful that I ran across it again. I am Michael Williams; aka @maadi mike. With that being said I will answer your f/u question from your reply. ~ Yes, I hear the feeder motor turn on and roll indicating it is ready to accept documents. It just will not pick the document up. I appears to try and pick up the paper it just doesnt'. I don't believe it is a sensor, motor or software malfunction. I believe that it is either a roller or gear. Any assistance you can offer will be gratefully appreciated. I have been searching all over the web looking for solutions including HP and have not found anything except for one YouTube video but it was difficult to follow and what I surmised from the video is that it ultimately resulted in a "gear", which was easily replaced and the printer worked fine after correcting the malfunctioning gear. Once again, thank you!
完成的
添加一条评论
1个答案
已选择的解决方案
Clean the pickup roller
  • Unplug the power cord from the product, and then remove the pickup roller.
  • Dab a lint-free cloth in isopropyl alcohol (electronic parts shops usually sell this), and then scrub the roller.
  • Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt.
HP have a video on their web site.
这个答案有帮助吗?
得分 2
2条评论:
Thank you very much for your reply to my question, by chance do you know what the title of the video is on either the HP Support site or YouTube? Thank you again. Note: The reason I am asking, I did a search using the title of this Post and J3680 and didn't come up with a good response. Thanks...
完成的
@maadi_mike No idea. It was just a general video for any number of model.
Here's one:
https://www.youtube.com/watch?v=eJBmi1_J...
You just want access to the paper feed area and the rollers. It is really just a generic sort of operation. Printer wise you printer would be considered an antique so exact documentation may be hard to find.
Take your time. Remember in troubleshooting the main action is doing nothing but looking and thinking slowly.
完成的
添加一条评论
添加你的答案
Michael Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 116
