跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
This page contains replacement, manuals, troubleshooting guides for Dell Vostro 5480 repair. Find troubleshooting and repair guides you need for your Dell 5480 repair at home.
Steps of replacing a Swollen Battery
I have detached the swollen battery but my question do I just put on the new battery or what should I do because I am afraid of the new battery being swollen as well. So my final question is, could there be a way to check why the battery is swollen so I can keep in mind when I am using or is there something wrong inside the motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Please tell me that you have taken out the swollen battery.
完成的
添加一条评论
1个答案
已选择的解决方案
iFixit has a very good guide for what to do with stolen batteries, which I will link here. To give the spark notes of the article, battery swelling occurs when the chemical reaction that is used to generate battery power no longer completes perfectly. This causes outgassing, which results in the battery swelling.
You need to turn off the device and do not charge it. You need to carefully remove the swollen battery and dispose of it properly.
To answer your question your new battery should be ok if it has been handled properly and if it is a new battery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jack Jin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 11
总计 99
