跳转到主内容
加入维修社区 - 创建账户
本页面包含 Dell Vostro 5480 的更换指南、手册和故障排除指南。你可以找到 Dell 5480 在家进行维修时所需的故障排除和维修指南。
Steps of replacing a Swollen Battery
I have detached the swollen battery but my question do I just put on the new battery or what should I do because I am afraid of the new battery being swollen as well. So my final question is, could there be a way to check why the battery is swollen so I can keep in mind when I am using or is there something wrong inside the motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Please tell me that you have taken out the swollen battery.
由完成的
添加一条评论
1个答案
已选择的解决方案
iFixit has a very good guide for what to do with stolen batteries, which I will link here. To give the spark notes of the article, battery swelling occurs when the chemical reaction that is used to generate battery power no longer completes perfectly. This causes outgassing, which results in the battery swelling.
You need to turn off the device and do not charge it. You need to carefully remove the swollen battery and dispose of it properly.
To answer your question your new battery should be ok if it has been handled properly and if it is a new battery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jack Jin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 271
