跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
20 个问题 查看全部
The tri point screw won’t come out
the screw driver seem to rolling in the the tri point screw head and it won’t come off, what can I do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure that you use the correct sized tri-point bit.
When unscrewing, try putting a bit more downforce to prevent the bit from coming up from the screw as easily.
If the screw already is a bit striped, try doing the same with the next bigger sized bit and this may help you. Just remember to be more careful when using the wrong sized bit since it may strip it even more if you don't get a good grip from the start.
Hope this helped and good luck! :D
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gilles Prescott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 88
