跳转到主内容
加入维修社区 - 创建账户
Asus Zen AiO Pro Z240IC 是一款一体式台式计算机,以其 4K 超高清屏幕和 1 TB 硬盘而闻名。
ASUS All-in-One Zen Reassembly Help
@jayeff Fix It, friends,
I have a 2018 Asus All in One "Zen" that I tore apart to replace the two hard drives and to upgrade the RAM. Unfortunately, two wires disconnected from the motherboard when I flipped the board over to replace the M.2 HD/card. I can't seem to find where they go on the board - frustrating.
Pictures: These two wires, one black and the other white; both of these wires lead to the top of the left screen (see pictures).
  1. I would like to know where these two wire leads go to, an antenna?
  2. Each end of the wires is not soldered, and the tips have a very small round connector. Once these two wires find their home on the board and would like to finish this project.
Who can assist me with this - please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@sdotraffic those are the wires for your WLAN adapter. They are antenna wires. Those should connect to the top of your WLAN card. Something like this
Give us the complete model number for your computer so we can verify this.
这个答案有帮助吗?
得分 1
7条评论:
@oldturkey03 turkey03 - good catch! I just returned home from work.
Here's the Asus model # Zen AiO 24 ZN242 Special Edition
I appreciate your assistance.
完成的
@sdotraffic just checked some of the few images about this model that I have available at it is the same setup as shown on this guide Asus Zen AiO Pro Z240IC Take a look at your WLAN card and you should see the two connectors.
完成的
Very helpful, I see where the two wires are to be plugged in. I assume then that the tape on the wires are to be over each connection point, correct? It's a project for the weekend. Thank you for your assistance @oldturkey03
完成的
@sdotraffic that sounds correct and the tape may even offer some EMI protection.
完成的
I've been out of commission for the past two weeks with the dreaded Covids, thanks for the help, everything went back together, and I only have one extra screw left!
完成的
显示更多的2条评论
添加一条评论
添加你的答案
John S 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 775
