跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
Adhesive inside display cut
Hi, unfortunately while changing the battery of my watch, I destroyed the bridge of the adhesive (with copper underneath) between the middle “island” and the right “island”. It should be connected like the left “island”. Hope someone understands and sees what I mean. Please see my photo.
Now, with the new battery, I cannot start the watch. The Apple symbol pops up for a few seconds, but nothing happens. Is this destroyed bridge the reason?
How can I repair the connection or get a spare part?
Thanks so much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Well, the battery was just ordered from ifixit. 😉
完成的
添加一条评论
2个答案
The copper adhesive strip is an EMI shield it doesn't effect the running on the watch. But the lifted edge could be pressing on the battery so I would use a jewelers burnisher to carefully press the edge down.
这个答案有帮助吗?
得分 0
2条评论:
Thanks so much for your quick answer.
What could be the reason that the watch is not starting?
The battery that I exchanged was bloated.
完成的
@oliver75 - Sadly, you really can only do swap out of the major parts like the display and the SIP if you are sure the battery is good.
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
oliver 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 87
