跳转到主内容
加入维修社区 - 创建账户
第一代 Altima 于 1992 年 6 月投产,作为 1993 年款车型发布。在 2004 年 6 月之前,所有 Altima 车型均在田纳西州士麦那(Smyrna)工厂生产。之后,为了满足旺盛的市场需求,日产位于密西西比州坎顿(Canton)的工厂也开始生产该车型。
has problems starting most of the time
I have a 94 Nissan Altima 4 cylinder that has problems starting most of the time. If I pull a plug out I am getting spark and it allows the car to start, but put it back in then it doesn't start... Help please...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Dave Scott could be many of things. If it has spark it most likely has spark when it is back in the cylinder head. So that would leave either fuel or air as a possibility. Check your fuel filter and pump to make sure that you have the right fuel pressure on that. The other thing you need to check for is that the spark happens a the right time. So you need to check the crank position as well as the cam position sensors. I would strongly suggest that when it runs, take it where they can scan the vehicle 's OBD to see if and what codes you get. Otherwise you might be spending a lot of money for parts that are not needed. Depending on where you are, places like Autozone do the scanning for free. Let us know what the exact engine is and what you have checked so that we may provide a more in depth answer
这个答案有帮助吗?
得分 0
3条评论:
I have replaced the fuel pump, battery, and fuel injectors it is getting gas, also should note that after replacing each the car started like the problem was fixed I shut it off came out next morning back to not starting, has me very confused. Was going to take it to shop down the road but won't start now..
由完成的
Sorry, forgot to also mention the spark plugs and wires were also changed recently.
由完成的
What about the cap and rotor?
由完成的
添加一条评论
添加你的答案
Dave Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 472
