跳转到主内容
加入维修社区 - 创建账户
Sony GTK-XB5 是一款 2016 年发布的高功率蓝牙家用音响系统。该音响系统提供黑色、红色和蓝色版本。
does not have sound?
.See attached image. I have the same issue and I believe the cause is this short on the motherboard where the solder has come off and is touching the other two solder points.
Update (01/20/2022)
Yes sorry same model number Panasonic max2000 it powers on fine. No power on at all.. Tried to reset. Still nothing. I did clean up those points to no avail. it was switched to 110v and powered on when it should have been on 240v.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
connor Hart it is possible. That cleans up relatively well with a soldering iron, flux and a desoldering wick. Looks like it is just used for a wire jumper. We would need to see what is on the other side,. also, let us know your Home Audio's exact model number. Since this was converted from an answer to its own question, the device may not be absolutely accurate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
connor Hart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 615
