跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 个问题 查看全部
How to reseal the Apple Watch screen?
My battery got swollen and pop-ed off the screen. Note that it’s just the actual screen that detached and not the part where force touch sensor is.
I don’t know how to re-seal this part, don’t see anything obvious. I replaced the battery and screen works, force touch also works.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Once you fix your problem you’re going to need some adhesive for it so stay in place and stick.
I fixit sells some in their shop
Apple Watch (38 mm) Screen Adhesive
Replace an adhesive strip compatible with the 38 mm case Apple Watch Original model and Series 1 and 2 models.图片
产品
$6.99
这个答案有帮助吗?
得分 0
1条评论:
That adhesive is made to connect the outer glass, where force touch gasket is.
That is not my case, see the photo I posted.
完成的
添加一条评论
添加你的答案
aleck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 259
