跳转到主内容
加入维修社区 - 创建账户
一款由 KitchenAid 在 2006 年生产的 10 速搅拌机。
Why does the planetary unit fall out?
The planetary unit falls out of my mixer. Nothing seems to be securing it. I can push it back in but it won’t stay.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
I, too, have a pre-2005 KitchenAid 600 Series Professional mixer and the same thing happened to me yesterday. There is nothing inside the mixer that seems to hold the planetary in. The top of the planetary has a lot of little grooves that appear to possibly hold the head in by friction. After spending some time finding a place for it to easily slip in (testing fit as I slowly turned it) I found a place where it slipped in easily. Before I rocked it in, I applied food-safe grease to all the gears. I then pushed it in and gave it a few taps with a rubber mallet to make sure it was seated. It seems to be working fine, but I will update if something else happens.
这个答案有帮助吗?
得分 1
1条评论:
After almost 5 years, it's still working!
由完成的
添加一条评论
I have the same problem. No set screw appears to be available. There is a spline on the bottom of the vertical shaft that connects to a corresponding spline on the planetary gear portion of the mixer. Nothing appears to hold this splines together, except friction. Any other ideas?
这个答案有帮助吗?
得分 1
2条评论:
Mine is still holding together when I assembled it as described above.
由完成的
Thanks Flipperroni. That is good to hear that your fix is lasting. I held a piece of wood on the top of the vertical shaft (after removing the gear grease cover) and hammered with a plastic mallet up from the middle of the planetary gear/beater attach area, to seat the splines together with some force. I hope that this holds as yours is.
由完成的
添加一条评论
There is what is called a set screw that holds the cap in place. this has probably backed out enough,. usually this is a HEX key and you just need to retighten it.
这个答案有帮助吗?
得分 0
6条评论:
No set screw is visible. Where could I find it? The planetary unit appears to be a friction fit.
由完成的
Maybe newer units have the set screw. Mine is 10 years old. Thanks
由完成的
@bjmg do u have a picture?
由完成的
Did you ever get a response. We have one that's 6-7 years old. Pro 620 limited edition.
由完成的
There is no set screw on a Professional 600 mixer.
由完成的
显示更多的1条评论
添加一条评论
@bjmg check to see if your unit still has the retaining clip and/or the pin to keep the planetary gears in place. Check the attached manual and see if that is consistent with your unit. Also, see if you have a proper model number on your unit so we can try to identify anything that might be specific to your mixers gears.. KitchenAid Planetary Gear Repair
这个答案有帮助吗?
得分 0
1条评论:
Thanks for supplying the manual. I forgot to my bad. And yeah that's the pin or screw i was taking about.
Also sometimes I've seen them just a friction fit. Did you try a rubber mallet and tap it down?
If neither are helpful you can use CA glue or tightbond red or purple to seal cap on
由完成的
添加一条评论
I just had a similar issue. At the bottom of the lower gear case housing there is a place that the lower center bearing fits into. In other words it's where the planetary shaft slides into the mixer, the piece with the big round mixing ring gear. The piece broke off that keeps the planetary shaft aligned and held in. I ended up using JB Weld to reattach it since the part had about a 2 week lead time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Betty Gallimore 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 30
过去 30 天: 68
总计 6,731
