跳转到主内容
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
Why does my phone say "moisture detected"when I plug my charger?
Details on bullet points because I will waffle I a para
•I have a charger that is a bit lose but works fine.
•Last night I kept my phone for charging but it would not charge,so I pressed harder which worked.
•Next morning I opened my phone's and it said it has to factory reset. I don't ha e much data on it so I allowed it .
•When I kept my phone for charge again,this time it said it has moisture in the cable or the port.
•What should I do to remove the moisture?Should I blow inside it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Btw I tested my charger on my friends phone and it works perfectly
完成的
添加一条评论
1个答案
最有帮助的答案
Sounds to me like the charge port may be bad, I've run into this issue several times and a charge port replacement always fixed the issue.
Phones can be weird especially since they have so much tech nowadays. Phones are most susceptible to moisture than anything else, taking it into the bathroom while you shower can cause moisture exposure or even damage. This may be what happened I'm not sure but the solution for sure would be to replace the charge port. Or replace the device.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for taking your time to.answer this
完成的
添加一条评论
添加你的答案
HelloDude 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 827
