跳转到主内容
加入维修社区 - 创建账户
三星第十代旗舰 Galaxy 手机,于 2019 年 3 月发布。出厂预装 Android 9.0 (Pie) 系统。
Touch screen not working
Hi
I have a samsung s10 the touchscreen has stopped working. It started at the top of the screen and it now has spread to the rest of the phone. I don’t want to do a hard reset as I have been unable to send pics etc to the cloud, thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Samsung s1p plus toch not working
由完成的 分享
El touch no funciona
由完成的 分享
添加一条评论
3个答案
最有帮助的答案
Clare Birtwhistle, the only way to fix this “It started at the top of the screen and it now has spread to the rest of the phone” is by replacing the digitizer. In this phone the display assembly is fused so unless you have the tools to separate it etc. it’s best to replace the display assembly. 三星g Galaxy S10 屏幕更换
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
Connect a USB mouse to the phone via an OTG cable and use the mouse to navigate through the phone so that you can backup your data to the cloud. Search online for Samsung S10 OTG cable to get results for suppliers that suit you best.
Be aware that the phone’s battery is used to power the mouse so it will discharge more quickly than normal.
After that you can replace the LCD screen + digitizer as described above, to fix the touch problem.
Replacing the screen assembly doesn’t require a hard reset so if you are careful, your data shouldn’t be affected. If you backup your data first nothing untoward will happen to it because of the repair, but odds are if you don’t then it will. Murphy’s Law.
这个答案有帮助吗?
得分 1
添加一条评论
https://youtu.be/w1m47ALwjGQ
I solved my problem by this video
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Clare Birtwhistle 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 44
总计 4,890
