跳转到主内容
加入维修社区 - 创建账户
Canon EOS 60D 是一款 1800 万像素的数码单镜头反光相机(单反),配备旋转式液晶屏。该相机于 2010 年 8 月发布,机身正面印有 EOS 60D 标识,方便识别。
Canon EOS60D USB Interface Board Replacement.
My Canon EOS60D was on a tripod with USB cable in place. Tripod was knocked over and camera landed on the Port side, meaning that the USB plug hit the floor first. Since then the USB connection has not worked although all other camera functions are fine including HDMI interface and remote trigger.
Is it possible to replace the USB interface board and if so, how? I’ve looked at your guides and none go as far as accessing the USB board.
Thanks in advance
Harry Watson
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hello!
Thankfully (since cameras are so pricey) they are generally repairable. However, parts can be difficult to find, especially for a camera of this age. Have you tried contacting either Canon support, or a local camera store? They will likely have parts, or be able to repair the board themselves. If they cannot, you could try to solder a new USB connector to the PCB. In the meantime (or if you determine it isn’t possible, too expensive, or too risky to try and fix the USB) try removing your SD card and read the data off of it.
这个答案有帮助吗?
得分 1
1条评论:
All this is good advice. Thanks for answering.
完成的
添加一条评论
添加你的答案
Harry Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 379
