跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
DualSense Mute Button Light
Just curious, did a quick teardown just to see the innards. I put the controller back together and everything is good except for one thing, which isn’t a deal breaker just a little annoying, the light on the mute button. The actual mute button works, as I have it mapped for my toggle mute on discord, but for whatever reason the light won’t go on, any help on this? And if I need replacement parts can someone point me in the right direction? Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Remove the controller case, see if the LED actually lights up.
If it lights up, probably the button wasn’t assembled correctly and the rubber cover got wrinkled up, blocked the light.
这个答案有帮助吗?
得分 1
3条评论:
Just did another teardown now, tested it with the motherboard facing me and the light does not goes on at all
完成的
Did you ever figure out how you did this? Cause I want to do this on purpose, &&^& this stupid mute light
完成的
The light is directly on the motherboard. Please check if all the cables are 100% connected as it should be. In the worst case, you need to replace the LED light there. This requires micro soldering, so it won't be easy. Contacting a local repair shop is then most likely the best thing to do. Sorry for the bad news..
完成的
添加一条评论
添加你的答案
Zacky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 862
