跳转到主内容
加入维修社区 - 创建账户
Xbox One 无线控制器型号 1697 发布于 2015 年,取代了型号 1537 控制器,并修复了 1537 型号中发现的一些问题。1697 型号控制器内置了 3.5 mm 耳机插孔,使其无需适配器即可兼容大多数第三方耳机。此款控制器已停产,并由型号 1708 控制器取代。
USB c port is jammed
i droped my controller on the floor with the cable in the usb c port and since then my controller is no longer detected by my computer and if won’t lock in the port. ( the cable still work, i have try with another cables )
how can i change/fix the usb-c port on my controller ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
kiyyou you will have to disassemble it. Use these guides Xbox One Wireless Controller (Model 1697) to get into it. The double check the logic board. See if the USB connector is cracked in a way that the board around the solder points had gotten damaged etc. If all of that looks okay you can try and source a replacement port from people like Dihgguket.com or Mouser.com etc. The post is soldered so you have t make sure you have all the tools and the know-how
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kiyyou 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 531
