跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Not displaying correctly after replacing digitiser
Hi. I have replaced digitiser, and before securing screws and sticking down I switched on to test. All seemed to be working perfectly so I went ahead, but after securing I had a problem with screen. I had a line across middle where everything above was perfectly positioned, but everything below was slightly too high. This meant I had party of notification bar repeated on bottom and Several rows of image missing in middle.
I opened up again to check everything connected properly, but have caused more problems. Image is repeated and jumping up and down screen, now cannot get past home screen. I think I may have neglected to disconnect battery the second time around and am now concerned I have damaged LCD.
What is the most likely cause of this?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
While it is hard to say the exact issue without seeing a picture of the problem, based on past experience I would be inclined to believe that the LCD was slightly cracked or damaged during the repair. You will likely need to replace it.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for your time in replying Ben. I have edited to include video, but doesn't seem to be showing.
Do you think the first issue was LCD, or could that be a faulty digitiser? I am wondering whether to order an LCD panel with another digitiser, or just the panel?
完成的
@mclarenchris Based on the videos you uploaded I would expect that the digitizer should be fine, problem likely lies with the LCD. I would start with that and if it solves the problem, then you won't have spent unneeded money on parts.
完成的
Thanks Ben, appreciate the advice ?.
完成的
添加一条评论
添加你的答案
Chris Reader 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 136
