跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Why are some of my keys not working?
So I did a battery replacement on my macbook due to getting the service battery option and the macbook acting weird. Before this everything else was working fine and turning on, but would occassionally shutdown with no warning.
The problem was narrowed to the battery IC or the battery so I went for the cheaper replacement before checking anything else. The battery was replaced following this guide and everything seems stable right now and is working but arbitrarily some keys just aren’t working.
The keys I’ve noticed not working are anything to the right of the j,m and i button; the function keys and the power button. The number buttons are working though oddly enough. I’ve tried reseating the keyboard ribbon cable but maybe I need to lift the logic board and check again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
If you have compressed air you can try blowing out the port for the keyboard cable on the logic board. In some rare cases that has resolved keyboard issues for me. You'll also want to inspect the condition of the pins on the keyboard cable (if you can, upload a close up picture of the keyboard cable head so we can take a look). Also, are there any signs of liquid damage? This would take the form of triggered liquid contact indicators (little red circles) or corrosion.
完成的
@zpl there shouldn't be liquid damage that I can see but I'll try and get an image up in a second. I live in a relatively humid place, those stupid liquid damage signifiers are meaningless cause even on a brand new macbook within an hour on a dry table they can trigger.
完成的
@zpl Here's the picture of the connector and port lit up https://cdn.discordapp.com/attachments/4...
完成的
just bumping this
完成的
just bumping this
完成的
添加一条评论
1个答案
If you are having issues with a couple keys on your keyboard the most likely culprit is the keyboard controller either on the logic board or on the keyboard itself. If it’s on the logic board then you will need to have one soldered on the logic board for you if you don’t feel safe (or don’t want to) doing it. If the controller is on the keyboard itself then you would need to replace the keyboard to fix that issue. Word of wisdom, depending on the model MacBook you own may require you to replace the entire upper frame as Apple has recently (within the past 5 or so years) began to make the keyboard and upper frame a single unit. I would recommend taking your machine to a laptop repair shop in your area that provides free diagnostics for additional assistance in this matter.
这个答案有帮助吗?
得分 0
1条评论:
this literally all started after the battery replacement a day or so ago. It was completely fine leading up to this and it was all tested beforehand. This laptop is also a macbook from 2013 so it's not one piece. We do not have free diagnostics places here
完成的
添加一条评论
添加你的答案
Nen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 61
