跳转到主内容
This guide page will help you diagnose problems with the Toshiba Satellite C55-B5200.
Why does my Laptop shuts down fully randomly?
I have a Toshiba Satellite C55-B
The problem started a few weeks ago, but now it’s appearing more frequently.
It will automatically shut down as if I held the power button, most of the time at windows welcome screen, but sometimes it also shuts down randomly while I am playing or browsing. It’s not overheating since I have a cooling pad and I have a thermal check program.
I also tried to disassemble it and clean up the power button if that might have been the issue, but it’s still the same.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi ,
Since you say it does this at startup, does it also happen if you start the laptop in safe mode. Since it is random you may have to try several times if it doesn’t fail in safe mode, just to make sure.
If it never fails in safe mode when starting, then you have a driver problem. Check that your drivers are all up to date, especially the video drivers.
If it also occurs in safe mode then check in Event Viewer for any Critical, Warning or Error events that are logged at the time the laptop shuts down that may give a clue as to what is happening.
If there are entries having the same Event ID number Source search online using the Event ID and Source information to find out what it means and what the cause may be.
To get to Event Viewer, press the Win key + x key (both together) and then click on the Event Viewer link that appears in the menu box.
When Event Viewer finally opens (be patient it may take a little while go to Event Viewer (local) > Summary of Administrative Events box to view all the events.
Double click on any entry that has multiple entries to get more information regarding the event.
As the problem is intermittent and random it may take a while to find but this may be a good place to start.
这个答案有帮助吗?
得分 2
4条评论:
Thanks for your help, I got the same critical error in Even viewer, here it is:
The system has rebooted without cleanly shutting down first. This error is caused because the system stopped responding and the hardware watchdog triggered a system reset.
If you know what that means then please let me know, because what i understood from it is that it's some sort of hardware issue?
完成的
@Abdullah Hafiz
What are the event ID and source numbers of the critical error?
Try getting into BIOS (press F2 and then release when laptop first starts) and check if it shuts off when in BIOS.
You may have to wait awhile etc.
if it is stable in BIOS it most likely is not a hardware problem as the only difference is that there is no OS loaded.
if OK try running an older version of memtest86 and check if the laptop stays on OK.
The idea here is that you're not testing the memory so much as testing the rest of the hardware as well to see if it stays powered on.
With getting into BIOS not much is happening as far as hardware goes but the memory test is utilizing other hardware systems on the motherboard.
Just eliminating things trying to narrow it down.
完成的
It is not stable in bios settings either.
I would love to give you more details about the critical errors, but now the laptop doesn't even go to windows welcome screen without shutting down
Ps: I noticed that everytime my laptop will NOT shutdown, the fan is spinning a bit loud, if it's spinng slowly, it will most likely crash.
完成的
@abbody1337
I realize that you said that you have a cooling pad and a thermal check program but I would still open the laptop and check that the fan is clean and dust free and also that the CPU thermal paste is OK and hasn't dried out and needs to be refreshed. If it has never been refreshed then after 6-7 years it really should be.
Here's the ifixit Toshiba Satellite C55-B5200 Fan Replacement guide that shows how to access the fan and here's a video that shows the CPU (5:15 minutes into the video]
Here's a video that shows how to remove / replace the thermal paste on a CPU.
The reason I suggest this is a loud fan is indicative of something getting too hot and needing to be cooled rapidly and the only thing in a laptop that gets hot is the CPU.
If it isn't cooled to within its normal operating temperature range the system will shutdown to prevent it being damaged.
I may be wrong about this but at least you know that if it still happens after you've done this then it is not a case of a dirty fan or dried thermal paste.
It could be a temp sensor problem but that is inbuilt in the CPU although I think that there are some on the motherboard as well but I don't know about Toshiba though.
完成的
添加一条评论
添加你的答案
Abdullah Hafiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 814
