跳转到主内容
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 个问题 查看全部
What is the max TBW rating for the SM841N?
I have a Samsung SM841N mSATA SSD I got in a pile of parts, and while it works it has 20.61 TB written so far to it. This is rather high for an SSD, but for a older SSD it’s probably not too unusual.
However, I need to know the max TBW before it “expires”, if you will so I can get an idea of how used it was before I got it. My application isn’t one where I can’t take chances since I just use it as a music SSD (although it only has 27GB left) and the files are on another drive I keep as a backup, so I do have them elsewhere.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @nick,
What size is it? 128gb, 256gb...,etc?
完成的
完成的
添加一条评论
2个答案
已选择的解决方案
It appears the SM841N mSATA was an OEM part for Dell based off the 840 Pro series SSD. Using Samsung’s warranty data for the 840 PRO series, they could be warrantied before 5 years or 73 TBW. If i were to give a conservative estimate you are sitting at less than a third of your SSD’s TBW.
这个答案有帮助吗?
得分 1
添加一条评论
The answer can be derived from the information you have already. 20.6TB has been written leaving an amount which equaled 82% of the max TBW. It means 18% of the max TBW is 20.6TB. Hence, max/100%TBW is 114TBW.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,006
