跳转到主内容
Check out these guides for information on repairing and dissembling your sewing machine.
Presser foot does not lower
Presser foot does not lower and when raising foot, lever feels tight. Have oiled part. Does not help. If left long enough, about 5 minutes, presser foot will lower.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi,
What is the make and model number of the sewing machine?
完成的
Sorry! That info would have been helpful. It’s a Bernini Record 930 Electronic. Thanks!
完成的
Bernina Record 930 Electronic
完成的
That seems quite a niche market. On the bottom of the pedal there should be a type number lik 'Type 213' or 'Type 290'. Which one do you have?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Don’t know about this machine but here’s the presser foot section from the service manual for a Bernini 930 that may help you to see what’s going on.
To check if the adjustment on your machine is correct you may have to improvise as I cannot find the “feeler gauge” mentioned in the manual but maybe you can place a 7.5mm object under the presser foot as described.
Sorry that I can’t be of more help on this.
这个答案有帮助吗?
得分 1
1条评论:
I will try suggestions and let you know in a few days. The machine is my Mom’s. Thank you!
完成的
添加一条评论
添加你的答案
Nancy Spooner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 332
