跳转到主内容
Windows 10 是微软发布 Windows 操作系统的主要更新版本。该系统发布于2015年。
My computer will not turn on
My computer has been having problems for well over a year now. A while ago it would not turn on unless it was plugged in so I started using my moms battery and my computer would turn on then but it would shut off later on. The battery works perfectly fine on her computer but not on mine.My computer will now absolutely not turn on at all. I'm thinking there is something wrong with the inside of the computer but I have no clue what.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @na7a133
Let us know the exact model of your computer, so we can check and provide you with better advises to check on it.
There could be some hardware issues on your computer.
完成的
@na7a133 my only guess is to replace your battery, since im guessing you use it alot
完成的
添加一条评论
1个答案
Since you are able to use your laptop when it is plugged-in, more than likely its good and your battery has reached its end of life. You may look at the specs on it and see what the supply output voltage is and check it with a multi-mete. Replace your battery and it should all be fine.
Also make sure to check out these methods the post provided.
https://www.minitool.com/data-recovery/f...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Natalee Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 174
