Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won’t heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, I recommend that you replace them as a set.
Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Flame Sensor
On a gas dryer, the flame sensor detects the heat emitted by the flame. If the flame sensor isn’t working, the dryer won’t heat. Before checking the flame sensor, first make sure that the igniter and thermal fuse are not at fault. To determine if the flame sensor is defective, use a multimeter to test the sensor for continuity at room temperature. If the flame sensor does not have continuity at room temperature, replace it.
3条评论
HI @grayashlyn38,
What is the model number of the dryer?
由 jayeff 完成的
@grayashlyn38 we would need to know exactly what was tested. What concerns me is that the thermal fuse needed to be replaced. Have you checked the heating element (this is an electric dryer, correct?). Like @jayeff mentioned already, we will need to know the exact model number for your dryer.
由 oldturkey03 完成的
Thank you!^ unfortunately ours is electric, we’re gonna try a few more things out tomorrow and if not I’m about to throw the whole dang thing away lol!
由 Ashlyn 完成的
