跳转到主内容
加入维修社区 - 创建账户
本页面提供 2017 年 6 月发布的华为 Honor 9 的维修指南、提示和技巧。
fingerprint button doesnt wwork after battery replace
Hello i replace my hono 9 battery like the guide on this topic
华为荣耀 9 电池更换
everything are good after i turned on my phone and battery works fine.
but the fingerprint button doesnt work. its completed dead.
thanks in advance
i reopened the phone and did the same like battery replace.
i saw a small scratch as you can see in picture in the black flex cable.
do you think that is the reason home button doesnt work?
should i try to replace it? and where can i find a guide for it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
borbou-13-  double check your work. Check the ribbon cables that are routed underneath the battery. Make sure those are all still properly connected. Inspect the ribbon cables carefully for any tears. There is really no other reason as for why the “fingerprint button” won’t work any longer.
这个答案有帮助吗?
得分 3
2条评论:
i reopened the phone and did the same steps as battery replace.
check the edited post to see the picture of the cable. you think i need to change it? and is there any guide for it?
thanks
由完成的
I would since it is possible that this is the cause for it. there is no specific guide for that flex so you will have to find the best way using a variation of all of these Huawei Honor 9
由完成的
添加一条评论
How was your fix, did you managed to get this working again?
这个答案有帮助吗?
得分 0
1条评论:
i have already ordered the flex wire and waiting the delivery.
由完成的
添加一条评论
添加你的答案
borbou-13- 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 726
