跳转到主内容
加入维修社区 - 创建账户
Bose SoundLink Color 是一款蓝牙扬声器,旨在作为 SoundLink Mini 更经济实惠且便携的替代品。
How to replace the USB charging port?
I have a Bose SoundLink Color, the USB charging port and the 3.5 mm jack are encased in this black piece of plastic, which does not seem extractable although it has two plastic pins visible from the other side.
How do you suggest to proceed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I am having this exact same issue right now. Guess my plan is to desolder the combined usb and aux component, then see if I can open it up, and eventually replace the USB part. Maybe solder new wires on the other side of the right pins and drill a hole in the side for a brand new duplicate USB port.
由完成的
添加一条评论
2个答案
最有帮助的答案
@hyklamin that is correct. The replacement comes like that. Here is the bad part, those are really hard to find and you may need to find a broken Soundlink to harvest that connector from there. Or, if you know somebody who can do 3D printing, make your own plastic casing with some options to slide a replacement USB port etc., into it. Then get some connectors from places like Mouser or Digikey and rig it up. PITA but doable. this is going to be more a re-engineering than a straight replacement.
这个答案有帮助吗?
得分 1
1条评论:
I am actually asking how to reach the base of the component I want to desolder. I can only think of melting the plastic.
由完成的
添加一条评论
hola . tengo el problema con el parlante , que no carga ni enciende,pude desconectar la bateria y tiene carga. entonces para mi la bateria no es el problema. estoy revisando componentes a ver que encuentro. adios.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yklamin 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 74
总计 4,648
