跳转到主内容
加入维修社区 - 创建账户
无论你走到哪里,都能带上动感十足的节奏。Sony SRS-XB10 便于携带,能为你的音乐增添更多低音效果。
cracking sound from the speaker
cracking sound is coming in medium and high volume of speaker and when the speaker gives up bass
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Down speaker damage change a parts
=== Update (11/15/2020) ===
Hello bass speaker change
由完成的
Where am i supposed to get the new bass diaphragm for replacement?
由完成的
添加一条评论
3个答案
最有帮助的答案
@kuleshwar could be a bad speaker coil or ripped speaker cone. You will have to take it apart and check the speaker separately. Of course there is always the chance that this is a bad amplifier (IC or circuit) again you won’t know until you check. Take a look on here for a teardown. After that post some good pictures of your pieces with your QUESTION so we can see what you see and possibly help you further.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
this happened to my sister it was just water damage
这个答案有帮助吗?
得分 0
添加一条评论
Same issue with my srs-xb10.
I’ve opened it just to found its actually the speaker itself having tear within its diaphragm. Sigh
这个答案有帮助吗?
得分 0
2条评论:
Hi i had the same problem that you, my speaker was cracked on my SRS-XB10. I tried fixing it with some Aleene’s Original Tacky Glue but it didn't work because there were many cracks and the speaker was just good for the trash.
I found one seller on Aliexpress that sells a 52mm speaker that looks almost exactly like the original Sony SRS-XB10 speaker and weights the same so probably the same Power. I ordered it, replaced the broken speaker with the new one (perfect fit) and it works like a charm, I didn't notice any major sound difference.
If you are interested the Aliexpress seller is "SOTAMIA Overseas Store" and search for "52mm 10W 4 Ohm Speaker"
https://www.aliexpress.com/item/10050031...
由完成的
do you think this one work work
https://www.aliexpress.us/item/325680398...
kinda wanna go over board lol
由完成的
添加一条评论
添加你的答案
kuleshwar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 74
总计 5,048
