跳转到主内容
加入维修社区 - 创建账户
Smartwatch from Samsung released in August 2020. The direct successor to the Galaxy Watch from 2018.
My watch doesn't keep charge
why does my watch not keeping charge. As soon as its off charge , the watch runs flat
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I suppose you made sure that there are no plastic covers over the charger or debris which could interrupt the charging. I also guess that you checked that the watch is actually charging when placed on the charger.
That said you could try and force restart the watch (once while off the charger and once while on the charger) to see if that solves the issue.
这个答案有帮助吗?
得分 1
添加一条评论
I recognize this is an old question. If the force restart does not work and the issue is “As soon as its off charge , the watch runs flat” it is the battery that no longer holds a charge. Start with that. If nothing else it will provide a known-well starting point should further troubleshooting be needed. Samsung Galaxy Watch3 Battery Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
M C 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 771
