简介
使用本指南来更换 Samsung Galaxy Watch 3 中的破旧或没电的电池。
如果电池膨胀,采取适当的预防措施。为了你的安全,在拆卸智能手表之前,请“使电池电量低于25%”。如果在维修过程中意外损坏了电池,则可以降低发生危险热事件的风险。
重新组装设备时,你需要更换粘合剂来重新安装新电池。
你所需要的
“”(如果可能)”,在安装新的胶粘剂并重新密封之前,请打开设备并“测试你的维修情况”。
用预先切割的胶带或双面胶带固定新电池。为了正确放置它,请将新粘合剂涂在设备中旧粘合剂所在的位置,而不要直接涂在电池上。
要重新组装你的设备,请按照逆序进行操作。
为了获得最佳性能,请“校准新安装的电池”:将其充电至100%,并继续充电至少2小时。然后使用你的设备,直到由于电池电量不足而将其关闭。最后,不间断充电至100%。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的论坛寻求帮助。
将您的电子垃圾带到R2或e-Stewards认证回收商。
26等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
18指南评论
Once I had the correct tools and replacement battery, fixing was easy. Tyvm!
One question, where can I find an authorized battery for this watch? or one that you highly recommend. Thanks.
**Edit - Your store doesn’t have a 45mm battery for my Galaxy Watch 3. Only 42 and 46.
The 42 and 46 mm models are the first Galaxy Watch sizes. We ’re working on getting the Watch3 batteries and parts but it may take some time.
Hi, is it possible to put the battery from samsung watch 472mAh, on samsung watch 3, instead of 340mAh?
Hi Andrey, short answer is no—although basically a good idea. But even if you cut the battery contact plate to fit (cut off the part with the alignment hole) its polarity is inverted. The Watch3 contact plate has -/+ (noted under the cable) whereas the original has +/-. Also the original Galaxy Watch battery is much bigger than the one in the Watch3. So it won’t fit inside the recess. Here is an image with the Watch3 battery on top of the original battery.
