跳转到主内容
加入维修社区 - 创建账户
Dodge Dakota(在生产的最后两年被称为 Ram Dakota)是克莱斯勒 Ram 部门(前身为 Dodge Truck 部门)推出的一款中型皮卡。第二代 Dakota 的开发始于 1991 年,但直到 1996 年才作为 1997 年款推出。
fuel gauge not working
fuel gauge is not working?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
New fuel pump and sending unit...no gas guage function.
Once it read full on an empty tank before I started the engine. After turning key on it went to empty. Gas light is always on with full tank.
Is it possible the wires were put back together backwards?
Same note...occaionally I have to pound on dash pad to get rpm and speedo to work...sometimes NO guages work til I smack the top of dash.
Help please...thanx
完成的
Okay...got dash to stop turning off...power harness was not connected securely...however...still have gas light on full tank and no guage function. Thinking the float is sticking against wall of tank as it is a new fuel pump and I didn't install it.
Previoust owner's grandfather did all the work on it. Well...drop the tank and see what 's what....
完成的
Ssssoooooo…it IS a brand new out of the box unit…what are your thoughts on this delimna?
Is it possible the idiot that installed it had placed the unit in wrong direction and the float it wedged against the wall of tank?
Drinking me insane with full tank and no guage function.
The guage works…it occasionally goes to full when ignition is off. ?????
#\€_:#! ”&\*&&€;:##_&;:” #\_.# anyway!!!
完成的
Could be your thermostat is sticking the truck gets hot shuts the ingine off your instrument gages don't show it being hot because the don't work
完成的
添加一条评论
1个答案
已选择的解决方案
This is a pretty common and annoying problem with the Dakotas'. Most likely it is the sending unit. You will have to drop the fuel tank and replace the fuel pump/filter assembly The sender, filter, and pump are all one assembly, so you'll need to buy a whole new pump assembly to change the sender. Of course you can, and should, also check your gauge to make sure that it is working okay. Use a meter to check your sending unit and see if you have any output. If that checks out, its your gauge. Here is a pretty good write up about how to do it....Hope this helps, good Luck.
这个答案有帮助吗?
得分 9
6条评论:
Sad but true and not cheap. +
完成的
Good to know! I looked up the price of the unit (pump/filter assembly)$80-$250, depending on where you want to buy it, etc. I also look up EVERYTHING on Youtube, and it is an easy fix for the Do-It-Yourselfer!
完成的
mí Dakota 98 consume demasiado combustible
完成的
no e tenido respuesta
完成的
What yoh post to set the fuel pump too
完成的
显示更多的1条评论
添加一条评论
添加你的答案
awaesaeh 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 88
总计 40,334
