跳转到主内容
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
isopropyl alcohol 90% replacement
Replacing my Apple Watch S1 screen. In the replacement instructions there are a couple places that says to use isopropyl alcohol 90% or better. Due to Covid-19 all the stores in my area don’t have any at this time. Is there a substitute I can use?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
IPA is mostly used to soften the adhesive. It doesn't help much
完成的
添加一条评论
2个答案
最有帮助的答案
The problem is you need something that will clean off the adhesive and not leave a film which messes up the fresh adhesive.
So your damed and double damed here ;-{
You can use ethanol but using it in a confined space can be dangerous both from the fumes and the risk of igniting the vapors! And you would need reagent quality which is also hard to find.
You’ll need to wait until you can find it or hunt it down - Sorry ;-{
这个答案有帮助吗?
得分 1
1条评论:
Thanks Dan for the straight forward answer. I'll have to keep calling our store each day to see if they get any in. Yep, I scrxxed for now.
完成的
添加一条评论
This might be a good time to mention that for electronics 99% isopropyl alcohol is safest and
for disinfectant 70% is most effective.
This web, though commercial, describes all the concentations and why best quite well.
https://blog.gotopac.com/2017/05/15/why-...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Goebel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 325
