跳转到主内容
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
Check if SMC was reset
I want to do an SMC reset and did so by powering off, disconnecting cable, holding pwr button, plugging in, powering on. But is there a way to verify i reset the SMC successfully? Resetting PRAM/NVRAM is clear because you hear 2 chimes
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I'm not sure I follow what you are looking for.
完成的
When you do the SMC reset, is there a way to know you did it properly? Like, sound cues, reset date/time or something like that. I want to know if i did it properly
完成的
添加一条评论
1个答案
已选择的解决方案
A SMC reset null’s the values it holds so there is no means to tell for sure. What is the problem you think an SMC reset will alter?
这个答案有帮助吗?
得分 1
1条评论:
It was high temps and weird fan controlling. But i think it did reset because the volume changed from max to 50%
完成的
添加一条评论
添加你的答案
Max Tech 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 219
