跳转到主内容
The Canon EOS 7D was Canon's first high end professional camera with an APS-C crop sensor.
Damaged mode dial on EOS 7D
Hi I've got a mode dial that's damaged, i.e. the button is damaged but works. I need to replace it along with the top plate. Can I do this without dismantling the camera?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Yes I do just seen video
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
How do you fix it? I have my dial button broken too.
这个答案有帮助吗?
得分 0
添加一条评论
You need to peel up the plate with the modes on these. Once you do that then you usually remove a screw in the center to remove the dial. The main thing you MUST DO is put it in full auto mode as this makes installation easier. This has worked for me on the ELAN 7, I very much doubt that Canon changed much between then besides the plate being a full cover part now.
这个答案有帮助吗?
得分 0
1条评论:
See the answer below, please.
完成的
添加一条评论
The hole button came off, it broke, its not just the plate. I don't know how to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cliff M cDiarmid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 337
