跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
iPad not turning on and heat on charging
iPad worked fine, then at the morning it didn’t turn on. At night it was about 50%+ of charge. I tried all solutions I found: charge it for hours, press Lock + Home in different variations, connect to Mac (with different combinations of buttons) – nothing helped.
The only sign it shows – heating on charge. Called to service, they said that iPads can’t be repaired and replacing unit will cost me $300. Didn’t plan to buy new iPad now, is there any more solutions to try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
There is a possibility of bad battery. I would try a new battery. Did you use an aftermarket charging cable? If you use a charging cable that was not an Apple cable or MFI Certified cable can cause the tristar ic to be damaged and it can cause it to not charge and no longer be able to transfer data. The aftermarket charging cables can cause voltage spikes that damage the tristar ic.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for the answer. No, I use original Apple cables. The only specificity of the iPad use was that it very often used until turning off due to low battery. It may cause the damage, I guess. How much repair would cost?
完成的
If you have someone do it around 100 dollars.
完成的
添加一条评论
添加你的答案
Guest User 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 217
