跳转到主内容
The Dell Inspiron 15 model number 7566 is a 15-inch gaming laptop that was released 2016-2017. It has graphics and performance at a mid-level for more casual gamers.
2 个问题 查看全部
How to install a new GPU?
I have a Dell Inspiron Gaming laptop with a 1060G-force graphics card, I wanted to know how to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It’s soldered on these - no replacing it :(. In addition, there is no TB3/USB-C to expand it, so you’re stuck where you are.
I would max the RAM out (16/32GB) and put an SSD in. I’d also repaste the machine, as dead thermal paste can kill your performance and these are old enough it’s a concern since it’s ~4 years old at this point, based on the age of the GPU (1060). Use a good thermal paste on this since it requires a complete teardown.
What tends to happen with the junk OEM paste Dell and all of the others use is it degrades to the point it isn’t even good for it’s intended purpose after 3-4 years. It isn’t a problem if you use them for 3-4 years and replace them regularly. The issue is if you keep it long term, then it needs to be done by at least the 5th year with 3 years being ideal since the paste is typically past being usable.
With this machine, you’re coming up to the 5 year mark where the paste is no longer viable for it’s intended purpose and it needs replacement.
Dell Inspiron 15 Gaming 7566 Memory Modules图片
指南
Dell Inspiron 15 Gaming 7566 Memory Modules Replacement
难度:
非常容易
55 seconds - 2 minutes
Dell Inspiron 15 Gaming 7566 Hard Drive图片
指南
Dell Inspiron 15 Gaming 7566 Hard Drive Replacement
难度:
简单
5 - 10 minutes
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dylan Hendricks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 489
