跳转到主内容
加入维修社区 - 创建账户
Dell Latitude E5530 是一款运行 Windows 7 专业版 64 位操作系统的便携式计算机,并配有耐用电池。这款笔记本电脑重达 5 磅,配备双核 i5 处理器、4 GB 内存,以及非常舒适的键盘和触控板。
Computer running too slow
I have a latitude e5530 running Windows 7 Pro with Intel Core i5, and it runs very slow. I start up the task manager, it only uses about 8% of the CPU on average. There is also something wrong with the speakers, there is usually either no noise or it is very faint. I put the volume to 100% and nothing changed. Is there a way to fix these problems?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Upgrade hard drive to SSD. This will improve performance.
Upgrading to Windows 10 would also spped it up. It is still a free update with legit W7, as far as I know.
I would especially think this with Task Manager showing only 8%. The old hard could possibly be ready to die.
What temperatures are CPU, etc.?
这个答案有帮助吗?
得分 1
5条评论:
How would I be able to see the details you ask for? I can't find the CPU temp in the Task Manager
由完成的
Do you know how to get to hardware monitor? it is a free software that can check temp, and other things etc.
由完成的
What's their site?
由完成的
@sjhralbert
Sorry have been doing TAXES for last few days.
https://www.cpuid.com/softwares/hwmonito...
由完成的
添加一条评论
Try cleaning the speaker. It helps with the noise. Take the speaker out of the computer, and brush off anything.
这个答案有帮助吗?
得分 0
3条评论:
Well, since this is a 11-year-old model, you have to take off the motherboard and all to see the speaker itself.
由完成的
And what about the slowness problem?
由完成的
No, for the speaker. I forgot that it...
由完成的
添加一条评论
All Dells have a Service Tag (like a serial number) on them. For that model, it will be on a sticker on the bottom, possibly under the battery. If you can find it, write it down.
Then, go to Dell’s, website here: https://www.dell.com/support/home/en-us/...
If found the Service Tag I mentioned, type it into the Dell website. This will give you all the system’s details, including how it was configured when it was originally built.
Regardless, all of the Dell software mentioned above can also be found on the same website, two tabs over. Or here: https://www.dell.com/support/home/en-us/...
Finally, this is everything you’ll likely need to dial that Dell back in (also on Dell’s website) https://www.dell.com/support/article/en-...
HTH
这个答案有帮助吗?
得分 0
添加一条评论
To fix the fan problem try cleaning the fan and shooting some air at the whole thing and for the speakers try looking where the connect cause they could be loose
这个答案有帮助吗?
得分 0
1条评论:
The whole thing meaning the whole computer
由完成的
添加一条评论
I fixed the speaker problem, apparently there was something wrong with my headphones. I used another set of headphones and the audio sounded as crisp as it used to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 30
总计 1,322
