跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
How to tell if battery is dead
I am trying to fix my 1st gen iPhone that I just bought as non working. It seems that the battery is bad, but I want to make sure that it's really the problem before ordering one. Whenever I tried to restore it in itunes or 3utools, it always tried to reboot and just turned the screen off every time. Sometimes, the backlight would turn off and a ghost of the screen could be seen for a few seconds. I can get the phone in DFU and recovery mode no problem, but as soon as I unplug it, it shuts off immediately. With the latest itunes I would get error 1604 and 1603. Is this likely the battery or is the dock connector or motherboard bad? I tried to download older itunes versions, but even on vista or Windows 7 machines I had no luck showing the “iphone software update server could not be contacted”.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Does it work O.K. with the power supply/charger plugged in?
If yes then replace the battery:
初代iPhone电池更换
If not them you have a more serious problem, I would imagine.
这个答案有帮助吗?
得分 1
1条评论:
The phone can get it DFU and recovery mode, but I can't boot up the phone or properly restore it, should I try changing the battery or is it a lost cause?
完成的
添加一条评论
Itunes is not longer supported by Apple, maybe that is why you got that error. Now Apple application is named Music App.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Gagnon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 124
