跳转到主内容
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
Is there a schematic for this logic board?
I have a ipad 5th gen. I have a couple pads pull off of the logic board leading to the power flex cable. I haven’t found a small enough wire or replacement, so when i start to solder the flex cable certain areas are to high for the others. I figured maybe I will run jumpers. And yes im learning solder lol.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
You can purchase a subscription to service for 69 dollars with all of the writing schematics. Go to ipadrehab.com. you can purchase and they will send you an access code and you can be online with it and less than an hour. The subscription is for 1 year.
这个答案有帮助吗?
得分 2
3条评论:
So have the jumpers in place. Im getting all the right voltages every where, however on the positive terminal it will read and then disappear. If i wait a few moments and try again, voltage comes back then nothing. Any ideas?
完成的
@areeves so you put the jumpers in place and it losing power when you test it? Have you gone past the jumper and checked if you have constant power then. You might not have a good connection with the jumper. I would check that.
完成的
I added a jumper and now I get a steady .7v to the board. Can I run more than one jumper from the flex cable to a single point on the board? Thank you for your help btw!
完成的
添加一条评论
添加你的答案
Anthony Reeves 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 740
