跳转到主内容
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
20 个问题 查看全部
How to Repair Nokia 5130 XpressMusic`s Music Player?
When I open the Music Player a message pops out and says not enough memory.
How can this be fixed? Pls. anyone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
9条评论
LMGTFY, It appears as if you need to flash your phone. Here is a site that will help you with backup files if you do not have a recent one. Check all the links. link 1 and here is link 2
完成的
You upgrade your device memory
完成的
This is an outdated issue, but I would still recommend you upgrade your storage, or you can use an SD card.
完成的
how to update
完成的
bhai jan nokia 5130 main player ka masla hy to kia kro jaldi btao plz
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
this is the software problem. this will not solve even after reset . you have to flash it means upgrade or install same version on it. this will solve this issue. if you have a dongles (Mx-key, Zaf, Ufs, Infinty, ATF(Advanced turbo flasher) any one from this . download the same Rm-495 latest version from support site then flash it . if you are normal user then you can use the Nokia software updater (download from Nokia site free software) then connect the file it will atumactically download the latest version and it will flash it . then you are ready . thumbs up. note that battery must be fully charged .
这个答案有帮助吗?
得分 5
5条评论:
+1 good answer.....
完成的
Bro This is a Software Problem Flash With This Version Nokia 5130 rm-495 v7.91
完成的
Mehak Mahoo, it is a good answer, but it is the same answer as the one from SIMRAN, except 4 month later. For that reason I moved it to his answer.
完成的
flash ic
完成的
what if there no update available for this device sofware or application updates
完成的
添加一条评论
添加你的答案
franjoshval123 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 43,456
