跳转到主内容
nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
这个答案有帮助吗?
得分 2
添加一条评论
screen unlock system rebooting and taking off the code.
这个答案有帮助吗?
得分 0
1条评论:
Would you mind putting this into a complete sentence?
完成的
添加一条评论
Repair on my screenlock chromatic code 2generation code.
这个答案有帮助吗?
得分 0
1条评论:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
完成的
添加一条评论
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 6,167
