跳转到主内容
加入维修社区 - 创建账户
更大尺寸的 Nintendo DSi,北美市场于2010年3月开售。大多数维修只需要螺丝刀和维修工具即可完成。
charging socket is broken can it be replace?
can the charge socket be replaced on the DSI XL?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Uh how much will it cost me to pay because the place where you plug in the charger into the ds it won't charge for a second
由完成的 分享
Uh how will I get my ds to you
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
kathy, follow this guide to remove your logic board 任天堂 DSi LL/XL 主板更换 you should find the power connector soldered onto the logic board. a new connector is available at places like this. Use a soldering iron to remove the old one and re-solder a new connector. Make sure you do not use to much heat to lift the solder pad. If you are unsure about doing it yourself, find somebody like a TV?Radio repair shop and see if they can solder it for you. Inspect the logic boards for any cracks, or other loose components. Good Luck.
这个答案有帮助吗?
得分 6
1条评论:
+good answer with sound advice
由完成的 分享
添加一条评论
yes go on nintendorepairshop.com or google dsi xl charge socket and they will show you. you send your ds in and they fix it for 54.99
这个答案有帮助吗?
得分 1
1条评论:
or how about he gets the parts for a few pennies, fix it himself and safe some money:-)
由完成的 分享
添加一条评论
http://www.ebay.com/itm/DSi-XL-Broken-Po...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kathy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 40
总计 6,445
