跳转到主内容
Apple 專為可望極致效能專業使用者所打造的產品線。目前, MacBook Pro 產品線包括 13、14、15、16、17 英寸機型,並且大致分為原始非一體成型機身、一體成型機身、視網膜螢幕、觸控列、Apple晶片五個世代。
Remove File Vault from user profile
As the question states, but…..
customer has a faulty HDD and it is been replaced with a new shiny SSD.
i cannot migrate the user data from all the accounts because 2 of them have file vault enabled. i was under the impression that FV encrypts the entire drive not individual user accounts.
when the migrate data window appears showing the user accounts to select, two of the users are marked as encrypted and cannot transfer the data.
can i disable FV from these accounts if i cannot load into them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The only way I was able to get around a multiple user account setup was to boot up under the drive with the old drive still connected with the new drive (Option key on boot), and then logging in user that I need to salvage the data under, then using Migration Assistant moving the users data across. If you want to break the encryption you’ll need to access File Vault under that account to undo it.
这个答案有帮助吗?
得分 1
6条评论:
hi there Dan, was waiting for your input :D /quote "to boot up under the drive with the old drive still connected with the new drive"
might be work stress but i have read that several times and still cant translate it. :D
cant login to the actual account that is encrypted with file vault, when i do so i get the error regarding fixing the home folder. have left it for over 24hours but it hasnt changed status.
完成的
Ouch!
Thats telling us the drive its self has issues that won't let us access to the account.
What is your exact model here?
完成的
OK what is the SSD you are using?
This series only offers a SATA II (3.0 Gb/s) drive interface so the drive you use needs to be able to run at this slower I/O speed. Most SSD's today are fixed SATA III (6.0 Gb/s) You'll need to find an older SATA II or an auto sense drive like a Samsung 860 EVO which will dial in to the systems I/O speed matching it. That could mess you up with migration or even cloning!
I think your only hope here is to try cloning the drive over But you will need to run Disk Utilities Disk First Aid on the drive first to make sure the HFS structure is in good shape.
Are you able to get the recovery keys from the customer to gain access to the volumes? Thats about it, sorry.
完成的
@danj we are using WD Green 480GB ssds on this occasion. its looking like the original drive has got worse and giving me less and less options. so i dont see a clone working, customer better have a back up :D
just for future reference, if the drive was working ok. how do you removed encryption from a single profile?
do you have to be logged in to the actual account you want to decrypt and just go to the file vault app in system preferences?
is there anyway to decrypt if you cant get in the user account?
we sell deslock full disk encryption and we can generate decryption files in situations like this, but i know very little about the ins and outs of file vault.
完成的
显示更多的1条评论
添加一条评论
from my experience i haven’t been able to get past that. Even with the HDD being faulty its tough to get the data off regardless. File vault will even stop you from manually doing a data transfer through terminal outside of the os. Its a pain.
这个答案有帮助吗?
得分 0
1条评论:
thanks for your input Das repair, its not looking hopeful for my customer.
happens a lot, customers enable things they have no idea about and then it $!^&* up their machines.
完成的
添加一条评论
添加你的答案
stuart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 123
