跳转到主内容
Released in 1999, the Braun Exact Power EP100 is an electric beard and mustache trimmer. It has an internal rechargeable battery.
3 个问题 查看全部
hair trimmer cut hair very short period, WANT TO CHANGE BATTERY
Type and capacity of battery to braun ep100
What volt
What watt
What mah
update
Great thanks for all who help me
update
Please if possible
Answer on one more question
Very important!!!
What capacity of battery must be in broun ep 100, there is 1 battery, but
What capacity?
500 mah or 1000 mha
Very important
Great thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
One of the clearest and most direct questions I've seen asked on Answers in my time here.
完成的
The higher the maH the longer it will last on a single charge.
完成的
the person who wrote the how to guide also said he used a higher mAh battery and his charger didn't last so long. something worth considering
完成的
添加一条评论
3个答案
已选择的解决方案
http://forum.eserviceinfo.com/viewtopic.... I found this link to how to get to the battery (page 2)but couldn't find what exact battery was in your trimmer. You will be able to find that by taking the trimmer apart and then matching it up after. good luck
这个答案有帮助吗?
得分 7
2条评论:
+ for finding out how to change it
完成的
Yes indeed--I looked for some time with no luck. +
完成的
添加一条评论
That wasn't easy to find but you need - (3 AA-size, 1.5V)
http://www.braun.com/global/male-groomin...
I'd also get a battery charger and rechargeable batteries like this one: http://www.google.com/products/catalog?c...
这个答案有帮助吗?
得分 5
3条评论:
Good research on your part also. +
完成的
Only the EP 15 and Allstyle use the 3 AA size batteries. the Battery on the EP 100 is soldered to the logic board
完成的
Very good OT, I missed that.
完成的
添加一条评论
Well here is a replacement R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm Fits Braun Models: Action Line, EP50, EP60, EP80, EP100, 540, 570 from here http://www.electricshaverstore.com/get_i... and here is the service documentation. The EP100 actually is a Braun 5601
这个答案有帮助吗?
得分 3
3条评论:
+ nice searching
完成的
+ You have a plethora of resources.
完成的
;-) Could not fix some of my old "stuff" without those resources. I actually purchase and repair according to the manuals I can get, makes my hobby easier.
完成的
添加一条评论
添加你的答案
IGOR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 6,411
